*triangle_clean_up
Fixes sliver/bad quality elements which fail the user-defined aspect ratio.
*triangle_clean_up entity_type mark_id <criteria>=<value>
HyperMesh Tcl Modify Command
- entity_type
 - The type of input entity. Valid values are elems and comps.
 - mark_id
 - The ID of the mark of input entities. Valid values are 1 and 2.
 - <criteria>=<value>
 - There are two possible criteria:
Examples
To correct all elements failing aspect ratio of 8:
*createmark components 1 "all"
*triangle_clean_up components 1 aspect=8 mode=3
   # Handle error
}Version History
2019
