*meshline_delete
Deletes meshlines.
*meshline_delete mark_id
HyperMesh Tcl Modify Command
This command deletes meshlines.
mark_id
The ID of the mark containing the meshlines. Valid values are 1 and 2.
To delete meshlines 100-200:
*createmark lines 1 100-200
*meshline_delete 1
   # Handle error
Version History
11.0
