*loadcreateonentity
Creates a load (forces, temperature, moment, velocity, acceleration, or constraints) on nodes, fixed points (surface vertices or weld points), surface edges, and surfaces.
*loadcreateonentity geomtype markmask config type component[1-6]
HyperMesh Tcl Modify Command
- geomtype
 - Type of entity the load is applied on (e.g. SURFS).
 - markmask
 - The ID of a mark containing the entities that will bear the load.
 - config
 - The configuration of the load:
- 1 - Force
 - 2 - Moment
 - 3 - Constraint
 - 5 - Temperature
 - 6 - Flux
 - 8 - Velocity
 - 9 - Acceleration
 - type
 - The type assigned to the load (as defined on the "load types" panel).
 - component[1-6])
 - Components of the load being applied.
To apply a temperature of 0 degrees on a surface
*createmark(surfaces,1) 12
*loadcreateonentity(surfaces,1,5,1,0,0,0,0,0,0)
None.
