HyperWorks NVH
HyperWorks NVH
2022
  1. Home
  2. Full Vehicle NVH
  3. Post-Processing and Diagnostics
    Define radiation conditions and create emissivity models.
  4. Load an NVH Utility
  • What's New
  • Get Started
  • Tutorials
  • Full Vehicle NVH
  • High Frequency NVH
Index
HyperWorks NVH
2022
HyperWorks NVH
  • What's New
    View new features for NVH 2022.
  • Get Started
  • Tutorials
    Discover NVH functionality with interactive tutorials.
  • Full Vehicle NVH
    • Assembly
    • Analysis
      Set up the simulation model, materials, domains and boundaries.
    • NVH Tools
    • Prepare Module
      Create, organize and manage the CAE parts.
    • Post-Processing and Diagnostics
      • Load an NVH Utility
      • Integrated Diagnostics
        Calculate a response, perform contribution analysis, plot results, and perform diagnostic studies and study response changes.
      • Modal Participation
        Plot modal/panel participation curves from an OptiStruct .h3d file or an MSC Nastran .f06/.pch file.
      • Grid Participation
        The Grid Participation utility allows you to plot panel grid participation results and then use advanced scaling contour capabilities to isolate key contributing areas.
      • Energy Distribution
        Visualize the distribution of energy within a full vehicle NVH model, as a way to understand what components are dominating the vehicle response.
      • Transfer Path Analysis
        Identifies the complex contribution of the excited structure through attachment points to a response in the responding structure.
      • Design Sensitivity Analysis
        Design sensitivity represents a change in response with respect to a change in a design variable, which is typically used for optimization.
      • Order Analysis
        Generates and post-processes engine order related data from an OptiStruct or Nastran frequency response analysis that contains either RPM-based loading subcases or order-based loading subcases.
      • Modal FRF
        Calculate a frequency response based on modal results.
      • Model Correlation
        The Model Correlation utility determines the degree of similarity or correlation between two sets of results.
      • Radiated Sound
        The Equivalent Radiated Sound utility post-processes the results of exterior structure-borne radiated sound.
      • Global Modes
        Identifies global modes from an OptiStruct or Nastran modal analysis.
      • Flow Induced Noise/General Signal Processing
        The General Signal Processing utility processes the time domain pressure results from CFD simulations and visualizes the results in both the time and frequency domain.
      • Mount Optimization
        Predicts powertrain rigid body mode frequencies and kinetic energy distribution, which play a critical role in optimizing the mount stiffness and layout configuration, by decoupling powertrain rigid body modes and reducing vibration transmission.
      • Optimization, RBDO
        Optimizes sensitive parameters for multiple sample analysis results using the RBDO approach.
      • Multiple Sample Analysis
        Post-process results from a Multiple Sample Analysis, including plotting a spread of responses (+/-95% and mean).
      • Display Options
        Customize plots using the following options
      • Filter Contributors
        Filters contributors to a smaller set of data.
View All Altair Simulation Help
HyperWorks NVH
HyperWorks NVH
2022
  1. Home
  2. Full Vehicle NVH
  • What's New
  • Get Started
  • Tutorials
  • Full Vehicle NVH
Index
Load an NVH Utility
From the NVHPost ribbon, select an NVH utility tool to display the NVH-Utilities Browser and start using the tool. The NVH Utilities include:
Tool NVH Utility
Modal/Panel Participation
Grid Participation
Energy Distribution
Order Analysis
Modal FRF
Correlation
Radiated Sound
Global Modes
Mount Optimization
MSA Structures
MSA Loads
MSA RBDO
