Flow Induced Noise/General Signal Processing
The General Signal Processing utility processes the time domain pressure results from CFD simulations and visualizes the results in both the time and frequency domain.
- For probe input, use the utility to generate frequency response curves.
- For surface input, use the utility to generate the dB maps contour and frequency filtered transient animation.
