Let
the temperature,
the pressure, and
the volume of the airbag at time
, and
the mass of gas
at time
are respectively temperature, pressure and volume of the
airbag at time
, and
the mass of gas
at time
Using , the variation of total gas energy can be written as:
(1)
which can be written as:
(2)
On the other hand, the basic energy equation
Thermodynamical Equations,
式 1 of the airbag and the expression of
enthalpy in
式 5 gives:
(3)
Where,
and
are characteristics of the inflator and are considered as
input to the problem.
and
can be estimated from the velocity at vent hole
is the variation of the external work. This estimation will be
described hereafter.
It comes from
式 1 and
式 2:
(4)
The variation of the external work can be written as:
(5)
Using
式 9, the last expression can be
written as:
(6)
The last equation can be introduced to
式 4:
(7)
The first order approximation
for each gas, which allows rewrite
式 7 as:
(8)
Which allows to determine the actual temperature
. The actual pressure then computed from the equation of
perfect gas (Thermodynamical Equations, 式 9).
