OS-E: 2025 Stamped Hat Section
Pattern grouping and shape variables can be used to optimize stamped plates that are difficult to deal with due to corners and sharp edges.
Automatic generation of topography variables does not take into account situations in which elements can be folded inside out when the variables are fully perturbed. This limits the draw depth that can be used with that technique.
Model Files
The model file used in this example includes:
hat.fem
Model Description
The following example demonstrates how this problem can be avoided with user-defined variables. All optimization set up is done using the Optimization panel and its subpanels in HyperMesh.
Figure 1. Loads and Constraints for the Stamped Hat Section
Figure 2. User-defined Shape Variables for the Hat Section
DTPG | 4 | DVGRID | 1 | ||||||
+ | 20.0 | 60.0 | YES | ||||||
+ | PATRN | 13 | 500.0 | 0.0 | 0.0 | 1.0 | 0.0 | 0.0 |
DESVAR | 1 | DV001 | 0.0 | 0.0 | 1.0 |
Figure 3. Plane of Symmetry for the Hat Section Model
Results
Figure 4. Variables Generated for the Hat Section
Figure 5. OptiStruct Solution for the Hat Section Optimization
The solution generated by OptiStruct is manufacturable using a stamping process. Also, the solution is very well behaved and needs little refinement to turn it into a production-ready design.
The optimized hat section increases the stiffness of the part by more than eightfold from the initial condition with no beads. The eight 'square' beads for the hat section, especially the four at the ends of the beam, are the key to bolstering the beam against shear collapse. Those beads also serve to prevent the flanges from folding under the bending load. OptiStruct has generated a strong design that supports both torsion and bending with restricted reinforcement possibilities. The shape and placement of the reinforcements are optimized resulting in a very efficient solution.
