/@TFILE
Engine Keyword The time at which the time history file begins.
/@TFILE
Tstart Δ T s a m p l i n g MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeiLdiaads fadaWgaaWcbaGaam4CaiaadggacaWGTbGaamiCaiaadYgacaWGPbGa amOBaiaadEgaaeqaaaaa@3F98@
N1 N2 ... NN
Field Contents Si Unit Example
Tstart Time at which the time history file begins to be written.
Δ T s a m p l i n g MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeiLdiaads fadaWgaaWcbaGaam4CaiaadggacaWGTbGaamiCaiaadYgacaWGPbGa amOBaiaadEgaaeqaaaaa@3F98@ Time frequency to write data on file.
N1 , N2 ... NN List of nodes.
  1. The name of the time history file is "Runname_0001@.thy".
  2. Only nodal velocities are saved in the file.
  3. When restarted if you specify the @TFILE parameters again (Tstart, Δ T s a m p l i n g MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeiLdiaads fadaWgaaWcbaGaam4CaiaadggacaWGTbGaamiCaiaadYgacaWGPbGa amOBaiaadEgaaeqaaaaa@3F98@ , list of nodes and the variables), the filtering is reinitialized and this may result in a non-contiguous TFILE. For a clean restart, just specify /TFILE without any parameters at all.
