/TFILE
Engine Keyword Defines the frequency of writing the time history file of T-file "RunnameTnn".
/TFILE/Type
Δ T h i s MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeiLdiaads fadaWgaaWcbaGaamiAaiaadMgacaWGZbaabeaaaaa@3AE8@
Type No value: Built-in format of current Radioss version.
= 1
Binary (not readable by most Radioss post-processors)
= 2
Coded ASCII 32-bit
= 3
ASCII
= 4 (Default)
Binary IEEE 32-bit
Δ T h i s MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeiLdiaads fadaWgaaWcbaGaamiAaiaadMgacaWGZbaabeaaaaa@3AE8@ Time frequency to write data on history plot file T-file.
  1. Recommended options are default (no value) or four, which can be read by HyperGraph.
  2. See "File Extensions and Formats" for detail on T-file name.
