/ATFILE
Engine Keyword Defines the frequency of writing additional time history file of T-file "RunnameTnnx".
/ATFILE/Type
Type | Output format.
Time frequency to write data on history plot file T-file. |
- This option is used to define the
frequency of writing additional time history files named
RunnameTnnx
(Tnna, Tnnb, Tnnc ...). The contents of these files are defined through the option /xTH (where x= A to I). These options use the same keyword format and variables as Time Histories, except for the addition of the prefix (/ATH, /BTH...). The frequency of output for the additional time history files is defined using /xTHFILE (where x = A to I). - Recommended options are default (no value) or four, which can be read by HyperGraph.
- See File Extensions and Formats for details of T-file name.
