/BEM/DAA
Block Format Keyword Doubly Asymptotic Approximation for Underwater Explosion, where the fluid mass matrix is computed by boundary element method.
/BEM/DAA/daa_ID/unit_ID | |||||||||
daa_title | |||||||||
surf_ID | grav_ID | ||||||||
C | Pmin | ||||||||
Xs | Ys | Zs | |||||||
Iform | Ipri | Ipres | Kform | Freesurf | Afterflow | Integr |
Pm | a |
fct_IDP | FscaleP |
Xc | Yc | Zc |
XA | YA | ZA | |||||||
Dir-X | Dir-Y | Dir-Z |
daa_ID | DAA block
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
daa_title | DAA block
surf_ID | Wet surface identifier.
2
3 (Integer) |
grav_ID | /GRAV
option identifier. (Integer) |
Fluid
density. (Real) |
C | Fluid sound
speed. (Real) |
Pmin | Pressure cutoff (<
0). Default = -1030 (Real) |
Xs | X-coordinate of standoff
point. 3 (Real) |
Ys | Y-coordinate of standoff
point. 3 (Real) |
Zs | Z-coordinate of standoff
point. 3 (Real) |
Iform | BEM solution flag.
(Integer) |
Ipri | Printout flag level.
(Integer) |
Ipres | Pressure loading flag.
6
(Integer) |
Kform | Analysis flag.
(Integer) |
Freesurf | Free surface flag. 6
(Integer) |
Afterflow | Afterflow computation.
7
(Integer) |
Integr | Time integer flag.
(Integer) |
Pm | Maximum pressure. 5 (Real) |
Decay
time. (Real) |
a | Maximum pressure constant.
5 (Real) |
Pressure decay time
constant. 5 (Real) |
fct_IDP | Incident pressure function
FscaleP | Ordinate (pressure) scale
factor for
fct_IDP. (Real) |
XC | X-coordinate of explosive
charge. (Real) |
YC | Y-coordinate of explosive
charge. (Real) |
ZC | Z-coordinate of explosive
charge. (Real) |
XA | X-coordinate of point A on
the free surface. (Real) |
YA | Y-coordinate of point A on
ZA | Z-coordinate of point A on
Dir-X | X-component of the normal
to the free surface plane. (Real) |
Dir-Y | Y-component of the normal
Dir-Z | Z-component of the normal
- The entire structure must be modeled. Symmetric analysis is not supported.
- The surface normal should be pointed into the fluid.
- Standoff point defined with
(Xs,
Ys,
Zs) is the location where the incident
pressure wave is given at time t=0:
Figure 1. - A plane wave can be simulated using a spherical wave and putting the explosive charge far enough away.
- Pressure at the standoff point as
a function of time is:
(1) Where,- Maximum pressure
- Time
- Decay time
The maximum pressure and decay time can be calculated using:(2) (3) - Explosive mass.
- Distance to the explosion.
- , α, and
- Constants depending on the explosive.
If in kg, in meter, in MPa and in ms.α TNT 52.12 1.180 0.0895 -0.185 PETN 56.21 1.194 0.0860 -0.257 HBX 53.51 1.144 0.0920 -0.247 - A free surface is a plane defined by a point and its normal vector.
- The afterflow normal velocity is
calculated as:
(4) - P
- Fluid point.
- C
- Explosive charge point.
- S
- Standoff point.
