/CONVEC
Block Format Keyword Describes the free or forced convective flux.
/CONVEC/convec_ID/unit_ID
convec_flux_title
surf_IDT fct_IDT sens_ID
Ascalex Fscaley Tstart Tstop H
convec_ID Free or forced convective flux block identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
convec_flux_title Free or forced convective flux block title.
surf_IDT Surface identifier.
(Integer)
fct_IDT Time function identifier for definition temperature in infinite room T inf ( t i m e ) .
(Integer)
sens_ID Sensor identifier.
(Integer)
Ascalex Abscissa (time) scale factor for fct_IDT.
Default = 1.0 (Real)
[ s ]
Fscaley Ordinate (temperature) scale factor for fct_IDT.
[ K ]
Tstart Start time.
(Real)
[ s ]
Tstop Stop time.
Default = 1030 (Real)
[ s ]
H Heat transfer coefficient.
(Real)
[ W m 2 K ]
Example (Thermal Loading)
#RADIOSS STARTER
/UNIT/11
unit for convection load
                kg                   m                   s
/CONVEC/1/11
convect with ambient air
#  SURF_ID    FCT_ID   SENS_ID
         4      2002         0
#             ASCALE              FSCALE              TSTART               TSTOP                   H
                   0                   0                   0                   0                 100
/FUNCT/2002
temperature of ambient air (with constant temperature 293K)
#                  X                   Y
                   0                 293
                   1                 293
#ENDDATA
  1. The convective flux is calculated using:
    (1)
    Q ˙ = H ( T − T inf ( t i m e ) )
    Where, T is the temperature (unit K).
  2. /CONVEC is not compatible with ALE applications (/ALE, /EULER). Thermal convection will not be applied to ALE nodes or ALE elements.
