/INTER/TYPE15
Block Format Keyword This interface is Ellipsoidal Surfaces to Elements Contact. It is a penalty contact interface without damping. This interface replaces interface TYPE14, especially if the mesh is coarser than the ellipsoid size.
The secondary surface must be a set of 3-node or 4-node segments (that is any kind of surface; except ELLIPS and MDELLIPS surfaces). The main surface must be a MADYMO hyper-ellipsoidal surface or a Radioss hyper-ellipsoidal surface, and Interface does not allow penetrations up to half the ellipsoid.
/INTER/TYPE15/inter_ID/unit_ID
inter_title
surf_IDs surf_IDm
Stif Fric
inter_ID Interface identifier.
(Integer, maximum 10 digits)
unit_ID unit_ID.
inter_title Interface title.
surf_IDs Secondary surface identifier.
(Integer)
surf_IDm Main surface identifier.
(Integer)
Stif Stiffness factor.
No default (Real)
[ N m ]
Fric Friction coefficient.
No default (Real)
  1. Interface stiffness is a nonlinear increasing function of penetration. Stif is the interface stiffness when the element enters the hyper-ellipsoid (that is when penetration is zero).
