/MPC
Block Format Keyword Defines multi-point constraints on nodes.
/MPC/MPC_ID | |||||||||
MPC_title |
node_ID1 | Idof1 | skew_ID1 | |||||||
node_ID2 | Idof2 | skew_ID2 | |||||||
etc | etc | etc | etc | ||||||
node_IDN | IdofN | skew_IDN |
MPC_ID | Multi-point constraint
MPC_title | Multi-point constraint
node_IDi | Node
identifier (Integer) |
Idofi | Degree-of-freedom
(velocity direction) (Integer) |
skew_IDi | Local skew (for each
DOF) (Integer) |
Scale
coefficient (Real) |
- This option is not available if it is
applied on:
- a translational DOF of a node with a null mass
- a rotational DOF of a node with a null inertia
- User-defined linear relation between nodal velocities.
- The N formats are necessary to define
a kinematic relation between N velocity components. Each term may be expressed
in its own local skew system (Skew_ID):
(1) = Skew_ID
= 1...6
1...3: translational velocity
4...6: rotational velocity
