/PROP/TYPE14 (FLUID)
Block Format Keyword Describes the general fluid property set.
/PROP/TYPE14/prop_ID or /PROP/FLUID/prop_ID | |||||||||
prop_title | |||||||||
Blank Format | |||||||||
qa | qb | h |
prop_ID | Property
prop_title | Property
qa | Quadratic bulk
viscosity Default = 10-20 (Real) |
qb | Linear bulk
h | Hourglass viscosity
coefficient Default = 0.10 (Real) |
Example (Fluid)
#RADIOSS STARTER
/PROP/FLUID/2
FLUID (unit kg_m_s) data from Example 39 - Biomedical Valve
# blank card
# q_a q_b h
1E-20 1E-20 .1
#ENDDATA
- The qa and qb default values are equal to 1.10 and 0.05 in non-CFD versions.
