/RWALL/LAGMUL
Block Format Keyword Defines infinite plane rigid walls using the Lagrange multiplier method. This keyword is not available for SPMD computation.
| /RWALL/LAGMUL/type/rwal_ID/unit_ID | |||||||||
| rwal_title | |||||||||
| node_ID | Slide | grnd_ID1 | grnd_ID2 | ||||||
| Dsearch | |||||||||
| XM | YM | ZM | |||||||
| Mass | VX0 | VY0 | VZ0 | ||||||
| XM1 | YM1 | ZM1 | |||||||
| type | Rigid wall type
keyword (see table below) |
| rwal_ID | Rigid wall
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| rwal_title | Rigid wall
title. (Character, maximum 100 characters) |
| node_ID | Node identifier (moving
rigid wall). (Integer) |
| Slide | Sliding flag.
(Integer) |
| grnd_ID1 | Node group defining
secondary nodes to be added to the rigid
wall. (Integer) |
| grnd_ID2 | Node group defining
secondary nodes to be deleted from the rigid
wall. (Integer) |
| Dsearch | Distance for secondary
search. (Real) |
| XM | X coordinate of M, if node_ID =
0. (Real) |
| YM | Y coordinate of M, if node_ID =
0. (Real) |
| ZM | Z coordinate of M, if node_ID =
0. (Real) |
| Mass | Mass of the rigid wall, if
node_ID ≠
0. (Real) |
| VX0 | Initial velocity in X
direction, if node_ID ≠
0. (Real) |
| VY0 | Initial velocity in Y
0. (Real) |
| VZ0 | Initial velocity in Z
0. (Real) |
| XM1 | X coordinate of
M1 (Real) |
| YM1 | Y coordinate of
M1 (Real) |
| ZM1 | Z coordinate of
M1 (Real) |
Rigid Wall Type
- Type
- Description
- PLANE
- plane
Surface Input Type
- Type
- Description
- PLANE
- MM1 defines the normal direction
- The first input to define the rigid wall is the coordinates of one point M or a node_ID in case of moving rigid wall.
- The next input is the coordinate of a point M1 and possibly a point M2 (in the case of a moving wall, M1 and M2 have the same motion as node_ID).
- The secondary nodes can be defined as a list by nodes and/or as the nodes that are initially at a distance less than Dsearch from the wall.
- The defined nodes must have a non-zero mass.
