/STAMPING
Block Format Keyword This option allows adapting error messages to stamping applications.
/STAMPING |
View new features for Radioss 2022.
Radioss format 2022 uses the 12x extension format.
Block Format Keyword In this group, keywords are used to set default value, global parameter, analysis type, input/output print, damping and ALE and CFD treatment for the whole model. For default value, it is still possible to overwrite in each specific keywords.
Block Format Keyword This keyword is used to set default values for certain parameters in all shell properties, but options could still be changed in each property set input and in this case, the latter will prevail.
Block Format Keyword Used to set default values for certain parameters in all solid properties and thick shells. The default values defined here will be overwritten by any values entered on the individual property input.
Block Format Keyword Defines interfaces TYPE2 default values.
Block Format Keyword Defines default value for TYPE7 interfaces.
Block Format Keyword Defines default values for TYPE11 interfaces.
Block Format Keyword Defines default values for TYPE19 interfaces.
Block Format Keyword Defines default values for all /INTER/TYPE24.
Block Format Keyword Defines default values for all /INTER/TYPE25.
Block Format Keyword This option allows different default values which are suitable for implicit calculations.
Block Format Keyword Describes the SPH global parameters.
Block Format Keyword In this group, keywords are used to set Rayleigh mass and stiffness damping coefficients, which apply to a set of nodes used to stabilize the results.
Block Format Keyword In Radioss, two node types are available. They use Cartesian coordinate to describe the position of each node.
Block Format Keyword In this group, keywords are used to combine material and property information (/PART), assemble model (/SUBSET) or define a separate model (//SUBMODEL).
Block Format Keyword Interfaces solve the contact and impact conditions between two parts of a model. Several interface types are available in Radioss and use different contact treatments.
Block Format Keyword Monitored volumes can be used to model an airbag, tire, tank, or any closed volume.
Block Format Keyword Radioss supports several different kinematic constraints, which are mainly used to impose acceleration, velocity, displacement or temperature in structure or constraint the moving of structure. They are mutually exclusive for each degree-of-freedom (DOF). Two kinematic conditions applied to the same node may be incompatible.
Block Format Keyword In Radioss the following load cases are available. Stress/strain as initial state could be considered by modeling, as well as pressure, gravity, and thermal load.
Block Format Keyword In this group, tools like transformation, frames, skews, and curve are introduced.
Block Format Keyword Adaptive Meshing is used in metal forming to divide the element to better describe the geometry. /ADMESH/GLOBAL and /ADMESH/SET are not available for SPMD computation.
Block Format Keyword Time histories output for different element groups, section output, or gauge output are described in this group.
Block Format Keyword Keywords that are still supported, but no longer maintained (*) are considered obsolete.
This manual contains an alphabetical list of LS-DYNA input files available in Radioss.
This manual contains the description of the Keywords for the Radioss Multi-Domain.
/STAMPING |
