Create Displacement Responses
Create displacement responses for the entire model, points, or individual parts.
From the Design Explorer ribbon, select the Responses
tool.
- Use the dropdown menu on the left side of the guide bar to select Displacement.
Choose one of the following:
Option Description Note Model Create a response for the entire model. Points Create a response for individual points. To create a response for each selected point or part, on the guide bar, click More Options, and turn on Add Response for Each Selection. To create a response only for the first selected point or part, turn off Add Response for Each Selection.
Part Create a response for one or more parts. - If you selected Points or Parts in the previous step, select one or more points or parts.
- On the guide bar, click to create the response.
- Optional: Make any desired modifications to the created response in the microdialog.
