Create Mass Responses
Create mass responses for the entire model or individual parts.
From the Design Explorer ribbon, select the Responses
tool.
- Use the dropdown menu on the left side of the guide bar to select Mass.
Choose one of the following:
Option Description Note Model Create a response for the entire model. Parts Create a response for one or more parts. To create a response for each selected part, on the guide bar, click More Options, and turn on Add Response for Each Selection. To create a response only for the first selected part, turn off Add Response for Each Selection.
- If you selected Parts in the previous step, select one or more parts.
On the guide bar, click
to create the responses.
