Starting an Application
NOTE |
· Before starting an application, ensure: o the CEP engine has been started o the prerequisite data sources are uploaded on the Data Sources tab o the application model is defined correctly · If the application is empty,
the
You can start an application either on the Applications tab or on the Application page.
Starting an Application on the Applications Tab
1. To execute an application, ensure the icon displays before the Name. This means the necessary data sources are already uploaded.
However,
if
is displayed,
right-click on the application and select
Data Source Usage on the context menu.
The list of data sources used by the application is displayed. For example:
Refer to Uploading Data Sources or Creating a Data Source for more information.
2. Click
The icon changes to
and the timestamp is displayed under the Status
Updated column.
The stream topics and the data producer are also generated.
