Troubleshooting: Can't Create a Fillet
Condition
When I try to create a fillet, it doesn't work and is displayed in orange.
Cause 1
The addendum doesn't completely intersect the binder.
Remedy 1
- Go back to the addendum Loft tool.
- Modify the ribs so that the addendum completely intersects the binder.
Cause 2
When creating variable edge fillets, the incorrect size was used.
Remedy 2
- Start by creating a smaller fillet, and then add larger fillets only at the necessary locations.
- Start by creating a larger fillet. Where a larger fillet fails, decrease the Radius to create a smaller fillet.
Cause 3
When trying to create a Loft Fillet, a hole is created instead of a fillet.
