Troubleshooting: Can't Select More Than One Part
Condition
I can't select more than one part. When I try selecting more parts, only the last selection is used.
Cause
You cannot select multiple disconnected parts. You need to combine them.
Remedy
Use the Combine tool to combine multiple disconnected parts into one connected part.
Now you can select the combined part when assigning the part.
