Create a token and associated API key for a bursting scenario. The API key is used in
the PBS cloud bursting hook.
You can create a token right after creating a bursting scenario or you can create a
token at a later date.
Login to Control.
Click the Cloud tab.
Click Bursting from
the Infrastructure menu located on the left-hand side of
the web page.
Select a bursting scenario by clicking its name.
Click Cloud.
Scroll to the Tokens section.
Click Add token.
For Name, enter a name for the token.
For Expiration date, use the calendar widget to specify
the expiration date.
Click Add Token.
An API key is generated and displayed.
Copy and save this API key.
The API key is only displayed once. It is pasted in the configuration file
used to configure the cloud bursting hook.
Click Close.
