Systematic Optimization
Setup Systematic Optimization.
Systematic method enables the analyst to setup a 1D topology optimization to highlight and find the prominent locations to add or position fixation points.
Optimization Deck Setup
Figure 1. Systematic Optimization Setup
Figure 2. Systematic Optmization Setup Panel
  1. Select the loadcase from Loadcase Selection and the required E-Line from Select E-Line lists.
  2. Choose the Optimization Direction.
  3. Click Load.
    This loads the model, post processing results, selected loadcase and E-Line into the session. HyperView window splits into four:
    • .H3D file of MTRAN analysis, showing selected interface and all 2D Parts.
    • Relative displacement graph for selected interface.
    • Relative Modal Contribution bar chart.
    • .H3D file of Modal Analysis.
  4. Select the required frequency from the Frequency range selection table.
  5. Enable the Auto Fill checkbox.
    This auto fills the Min. (Hz) and Max. (Hz) value fields. If only one frequency is selected, Single Freq. (Hz) is auto filled.
