View new features for HyperWorks 2022.1.
The Aerospace menu provides you with access to various aerospace tools.
Use the Result on Stack tool to display layer based shell results along with the real stacking sequence of the selected element(s).
Use the Layer Book tool to contour required results, select layers and load cases, and choose an export option.
The NVH menu provides you with access to various NVH utilities.
Use the Safety ribbon to access crash and safety post-processing tools.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
