View new features for HyperWorks 2022.1.
The Aerospace menu provides you with access to various aerospace tools.
This tool allows you to have the same system defined in both HyperView and HyperMesh.
The NVH menu provides you with access to various NVH utilities.
Use the Safety ribbon to access crash and safety post-processing tools.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
