Deformable Curves
Use the Deformable Curves tool to create and edit deformable curves.
In MotionView, a deformable curve entity is used with advanced joints that require a curve entity. The deformable curve can connect to one or more bodies and can deform during the simulation.
Create Deformable Curves
- Activate the Create explicit graphics check box to create a graphic associated with the deformable curve.
