PAM-CRASH 2G Conversion
PAM-CRASH 2G to Radioss Conversion Mapping
Elements
| PAM-CRASH 2G | Radioss |
| BAR | TRUSS |
| BEAM | BEAM |
| SPRING | SPRING |
| SPRBM | SPRING+PROP/SPR_BEAM (TYPE 13) |
| MEMBR | SH3N, SHELL |
| SHELL | SH3N, SHELL |
| SOLID | BRICK |
| TETRA44 | TETRA44 |
| MASS | ADMAS |
| PLINK | SPRING+INTER/TYPE2 |
| KJOIN | SPRING+PROP/KJOINT(TYPE33) |
Boundary Conditions
| INIVEL | INIVEL |
| BOUNC | BCS |
| CONLO | CLOAD |
Systems
| FRAME | FRAME |
Materials
| MAT_1D TYPE 201 | M1_ELASTIC |
| MAT_1D TYPE 220 | PROP/SPR_GENE |
| MAT_1D TYPE 223 | /PROP/SPR_BEAM |
| MAT_2D TYPE 100 | M0_VOID |
| MAT_2D TYPE 101 | M1_ELASTIC |
| MAT_2D TYPE 102 | M36_PLAS_TAB |
| MAT_2D TYPE 103 | M36_PLAS_TAB, M44_, COWPER |
| MAT_2D TYPE 105 | MAT36/MAT2 |
| MAT_2D TYPE 117 | MAT36/MAT2 |
Curves
| FUNCT | FUNCT |
Control Cards
| TITLE | TITLE |
| OCTRL/ | |
| DSYOUPUT | /ANIM/DT |
| THPOUTPUT | /TFILE |
Components
| PART | PART |
Contact Interfaces
| CNTAC36 | INTER/TYPE7 |
| CNTCT33 | TYPE7 |
| TIED | /INTER/TYPE2 |
Properties
| MPART(Type=Solid) | /PROP/SOLID |
| MPART(Type=Shell) | /PROP/SHELL |
Rigid Walls
| RWALL | RWALL |
Time History
| THELE | TH/SHEL, SH3N, SPRING, BRIC |
| THNODE | TH/NODE |
| THLOC | TH/FRAME/ACCELEROMETER |
Sections
| SECFO | SECT |
Sets
| GROUP(components) | SURF/PART/EXT |
Groups
| GROUP | GRNOD |
Airbags
| BAGIN | MONVOL |
