HyperWorks writes several different settings files.
            HyperMesh writes command<#>.tcl,
                    hmmenu.set and hmsettings.tcl
                (standalone only). HyperWorks writes
                    hwsettings.xml. Each of these files is detailed below.
        command<#>.tcl
            The command file is a command history file containing the commands executed in
                    HyperMesh whenever any operation is performed. This
                file can be used to rerun operations or as a basis for determining the commands
                required to automate a given process. By default, the command file is written to the
                start-in directory for each session. It is possible to customize the location where
                this file is written to using the HM_COMMANFILE_DIR environment variable.  Note that
                on Linux, the command file is named command.tcl.
        hmmenu.set
            The
hmmenu.set file stores information about
panel options,
panel settings, user
                profiles, graphics settings, element check settings, penetration check settings and
                several other settings. The
hmmenu.set file is written to the
                start-in directory after each session is closed. Deleting this file resets the
                stored settings to their default values. It is possible to customize the location
                where this file is read from during start-up.
HyperWorks uses
                the following search order to find the
hmmenu.set file. If
                copies exist in multiple locations, only the first one found in the search order is
                    used.
                    - HM_MENUSET_DIR environment variable
                    - Start-in directory
                    - Home directory
                    - HW_CONFIG_PATH environment variable
                    - Installation directory
        hmsettings.tcl
            The
hmsettings.tcl file stores information on the
browsers, the user interface layout (tab locations,
command window,
panel location, toolbars,
                and so on), keyboard preferences, import/export settings, recent files, and other
                various settings for
HyperMesh standalone. By default,
                the
hmsettings.tcl file is written to the My Documents
                directory on Windows and in
~/.altair on
Linux after each session is closed. Deleting this file resets
                the stored settings to their default values. It is possible to customize the
                location where this file is read from during start-up and written to on exit.
HyperMesh standalone always writes the
hmsettings.tcl file back out to the location where it
                originally read it from for that session. The following order is used to find the
hmsettings.tcl file.
                    - HM_SETTINGS_DIR environment variable. If this is defined, the search stops
                        even if the file does not exist.
                    - My Documents directory on Windows or ~/.altair on
                            Linux.
        hwsettings.xml
            The
hwsettings.xml file stores information on the
command window,
                various settings. By default, the
hwsettings.xml file is
                written to the My Documents directory on Windows and in
~/.altair on
Linux after each
                session is closed. Deleting this file resets the stored settings to their default
                values. It is possible to customize the location where this file is read from during
HyperWorks always writes the
hwsettings.xml file back out to the location where it
hwsettings.xml file.
                    - HW_SETTINGS_DIR environment variable. If this is defined, the search stops
                            Linux.
