Turn a Curve On or Off
Or
View new features for HyperWorks 2022.1.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
Existing curves can be edited individually and new curves can be added to the current plot using the Define panel.
Allows you to create macros that produce curves and notes for plots.
Retrieve individual point data on any curve in the active window. When a point is selected, the point data is displayed on the panel.
Add horizontal and vertical datum lines to plots.
Annotate plots using notes.
Or
