Tracing
Use the Tracing tool to trace system, component, and node entities during animation.
Figure 2. Tracing PanelView new features for HyperWorks 2022.1.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
Figure 2. Tracing Panel© 2022 Altair Engineering, Inc. All Rights Reserved.
