HyperWorks
HyperWorks
2022.1
  1. Home
  2. Entities and Solver Interfaces
  3. Named Entities
    Entities which are given a name but are not collected or organized into containers.
  4. Mechanisms
    Mechanism entities are the root of the hierarchy in the Mechanism Browser.
  • What's New
  • Get Started
  • Video Tutorials
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
Index
HyperWorks
2022.1
HyperWorks
  • What's New
    View new features for HyperWorks 2022.1.
  • Get Started
  • Video Tutorials
    • Collectors and Collected Entities
      Collectors are named organizational containers for collected entities. Collected entities are nameless entities which must reside within one, and only one, collector. Collected entities are mutually exclusive to a collector.
    • Named Entities
      • Accelerometers
        Accelerometer entities measure acceleration in the simulation.
      • Ale Fsi Projection
        Ale Fsi Projection entities provide a coupling method for simulating the interaction between a Lagrangian material set (structure) and ALE material set (fluid).
      • Ale Reference System Curve
        Ale Reference System Curve entities defines a motion and/or a deformation prescribed for a geometric entity, where a geometric entity may be any part, part set, node set, or segment set.
      • Ale Reference System Group
        Ale Reference System Group entities used to associate a geometric entity to a reference system type.
      • Ale Reference System Node
        Ale Reference System Node entities defines a group of nodes that control the motion of an ALE mesh.
      • Ale Reference System Switch
        Ale Reference System Switch entities allows for the time-dependent switches between different types of reference systems, that is, switching to multiple PRTYPEs at different times during the simulation.
      • Ale Smoothing
        Ale Smoothing entities constraint keeps an ALE secondary node at its initial parametric location along a line between two other ALE nodes.
      • Ale Tank Test
        Ale Tank Test keyword provides curve through an engineering approximation when control volume airbags only require two engineering curves to define gas inflator and those two curves can be experimentally measured but the ALE inflator needs one additional state variable - the inlet gas velocity which is impractical to obtain.
      • Analysis
        Analysis entities stores settings and entities for composite stress toolbox calculations.
      • Attachments
        Attachments facilitate the ease of joining subsystems.
      • Blocks
        Block entities are enclosed volumes represented by a "box" or block.
      • Bodies
        Body entities define a kinematic assembly made of FE parts or nodes.
      • Boxes
        Box entities are enclosed volumes, which are represented by a box.
      • Comments
        Comments provide a convenient way to add lines of text in the solver deck, which are considered as commented lines by the solver.
      • Constrained Extra Nodes
        Constrained extra node entities define and store the keywords *CONSTRAINED_EXTRA_NODES_NODE and *CONSTRAINED_EXTRA _NODES_SET.
      • Constrained Rigid Bodies
        Constrained rigid bodies entities define and store the keyword *CONSTRAINED_RIGID_BODIES.
      • Constraints
        Constraints define kinematic constraints on a node's degrees of freedom.
      • Material Behaviors
        This entity defines additional material features coupled to the referenced material, like: Failure, Permeability, Porosity, Thermal, Fatigue, Cohesive, Inelasticity, and so on.
      • Mechanism Constraints
        Mechanism Constraint entities define kinematical constraints on a body at a specified node or point location.
      • Contact Surfaces
        Contact surface entities define and store contact definitions typically used in contact analysis.
      • Control Volumes
        Control volume entities define and store control volumes typically used in safety analysis.
      • Cross Sections
        Cross section entities store cross section definitions used in a crash analysis.
      • Curves
        Curve entities define and store xy data and are associated with a plot entity.
      • Damping
        In LS-DYNA, damping entities define damping applied on the parts and nodes in case of *DAMPING_GLOBAL. In Radioss, damping entities used to set Rayleigh mass and stiffness damping coefficients are applied to a set of nodes used to stabilize the results.
      • Dummy
        Dummy entities are defined by bodies representing the different kinematic assemblies of the dummy.
      • Element Clusters
        Element clusters are used to describe an assembly of elements for post-processing and failure control.
      • Engine Files
      • Failures
        Failures describe material failure criteria to be coupled to material models.
      • Features
        Feature entities track and manage certain geometric features.
      • Fields
        Field entities store spatially varying values, which can later be realized (mapped) to the element and node data of a new target mesh.
      • Frequency
        The Frequency entity supports the solver keywords to set up NVH, Durability, or Acoustic analysis.
      • Frictions
        Frictions entities define friction coefficients between parts.
      • Groups
        Group entities define and store interfaces and rigid walls typically used in contact analysis.
      • Hourglass
        Hourglass entities define hourglass and bulk viscosity properties which are referenced via HGID in the *PART command.
      • Integration Rules
        Integration Rule entities specify user-defined integration points for beam and shell elements.
      • Interface Component
        Interface Component entities create an interface in interface file for use in subsequent linking calculations.
      • Interface Linking
        Interface Linking Discrete keyword link node(s) to an interface in an existing interface file.
      • Joints
        Joint entities define the kinematic relationship between two bodies (for Ball, Cylinder, Revolute, Slider joints) or three bodies (for DoubleSlider joints).
      • Laminates
        Laminate entities define the list of stacked plies which make up a laminated structure.
      • Load Steps
        Load step entities define and store load cases for a given analysis.
      • Load Step Inputs
        Load step inputs organize and manage the IDs of analysis parameter bulk cards.
      • Materials
        Material entities define and store material definitions for a model.
      • Mechanisms
      • Mesh Groups
        Mesh Groups, also called Assemblies, are specific to the EXODUS profile.
      • Output Blocks
        Output block entities define and store solver output requests.
      • Parameters
        Parameter entities parameterize FE entity and geometric entity attributes.
      • Perturbations
        Perturbation entities provide a means of defining deviations from the designed structure, such as buckling imperfections. Define the stochastic variation in the material models with the STOCHASTIC keyword option.
      • Plies
        Ply entities define composite lamina.
      • Plots
        Plot entities associate and organize curve entities within a xy plot window.
      • Positions
        Position entities allow you to apply a Transformation sequence on set of nodes or SolverSubmodels.
      • Pretensioner
        Pretensioner entities define pretensioners.
      • Properties
        Property entities define and store 1D, 2D, and 3D property definitions for a model.
      • Reference Geometries
        Reference Geometries define the reference shape of foam or airbag components.
      • Regions
        Region entities store information used to facilitate and automate modeling practices and processes. It enables a selection which can be common across design changes or other models, provided region data is the same.
      • Retractors
        Retractor entities define retractors.
      • Rigid Bodies
        Rigid bodies entities define and store the keywords *RBODY and *RBADD.
      • Rigid Walls
        Rigid wall entities provide a method for treating a contact between a rigid surface and nodal points of a deformable body. In the LS-DYNA and Radioss user profiles, rigid walls can be created in the Model and Solver browsers.
      • Sections
        Section entities define and store a model's 1D and 2D properties.
      • Sensors
        Sensor entities define and store sensors typically used in safety analysis.
      • Sets
        Set entities define and store lists of entity IDs for entities, sets of sets, or lists of set IDs.
      • Slip Rings
        Slip ring entities define sliprings.
      • Solver Masses
        Solver masses are used to model lumped mass finite element mesh.
      • State Equations
        State Equations are used to describe the thermodynamic equation relating material state variables under a given set of physical conditions, such as pressure, volume, temperature, or internal energy. State Equations are useful in describing the properties of fluids, mixtures of fluids, and so on.
      • Tables
        Table entities collect data points.
      • Tags
        Tag entities tag a piece of information, called the body, onto a node, element, line, surface, point, or solid within the model.
      • Terminations
        Termination entities provides an alternative way to stop the calculation before the termination time is reached.
      • Titles
        Title entities attach a title box with text to the modeling window, or to a node, element, load, or system.
      • Transformations
        Transformation entities define solver transformations, and are used to define a transformation sequence in a Position entity, to be applied on a set of nodes or on a SolverSubmodel.
    • Morphing Entities
      Entities used for morphing the shape of FE model.
    • Optimization Entities
      Entities used to set up optimization problems.
    • Control Cards
      Control card entities create solver control cards such as results file I/O options, CPU and memory limits, and others.
    • Undefined Entities
      Undefined entities are entities that will not be written to the solver deck.
    • Solver Encryption Entities
      The encryption of solver entities is used to translate entity data into an undisclosed language.
    • Element Property and Material Assignment Rules
      Element property and material assignment rules are based on the current user profile (solver interface).
    • Supported Cards
      Supported cards organized by solver.
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
View All Altair Simulation Help
HyperWorks
HyperWorks
2022.1
  1. Home
  3. Named Entities
  4. Mechanisms
  • What's New
  • Get Started
  • Video Tutorials
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
Mechanisms
