Sections
Section entities define and store a model's 1D and 2D properties.
Sections have a display state in the modeling window. The elements can be visualized based on the section color. Section is mapped to the property entity.
ANSYS Cards
| Card | Description |
| BEAM | Defines the beam section. |
| CONTACT | Defines the contact section and has one of the following subtypes:
| JOINT | Defines the Joint section and has one of the following subtypes:
| LINK | Defines the link section. |
| PIPE | Defines the PIPE section. |
| PRETENSION | Defines the Pretension section. |
| SHELL | Defines the Shell section. |
| TAPER | Defines the Taper section. |
