Edit Beams
Align, orient, and offset 1D elements, and release degrees of freedom.
View new features for HyperWorks 2022.1.
Edit the Parameter and Criteria files and define mesh controls using the Mesh Controls Browser.
1D mesh that allows accurate testing of connectors, such as bolts, and similar rod-like or bar-like objects that can be modeled as a simple line for FEA purposes.
Supported 1D elements.
Use the Beam Sections tool to create and edit standard beam sections, cross beam sections, and HyperBeam sketches.
Use the Member Mesh tool to create 1D elements on edges, free lines, nodes, or members.
Use Stiffener Mesh tool to create 1D elements as shell stiffeners from orphan lines representing trailing edges.
Use the Edit Beam: Align tool to reorder the N1 to N2 sequence of 1D element nodes.
Use the Edit Beam: Orient tool to define bar2 orientation vectors or orientation nodes.
Use the Edit Beam: Offset tool to manually set offsets or adjust beams on plates.
Use the Edit Beam: Pins tool to edit and release degrees of freedom.
Use the Review tool to plot area moments of inertia and stiffness.
Use the Section Property tools to update properties assigned to bar2 elements (target) using a cross section on various entities as the source.
Use the Inflate tool to create 2D shell mesh or 3D solids from 1D beams.
These tools enable the creation of 1D elements from surface lines, organizing them into components. They also offset/orient these elements based on the attached shell elements and calculating properties of these 1D elements from 3D solid or shell FE element sections.
A surface mesh or "shell mesh" represents model parts that are relatively two-dimensional, such as sheet metal or a hollow plastic cowl or case.
Volume mesh or "solid meshing" uses three-dimensional elements to represent fully 3D objects, such as solid parts or sheets of material that have enough thickness and surface variety that solid meshing makes more sense than 2D shell meshing.
ON THIS PAGE
ON THIS PAGE
