View new features for HyperWorks 2022.1.
Use the Part Browser to create, organize and manage the CAE part structure/hierarchy.
A part is an engineering representation of a physical part, and a part assembly is a group of part assemblies and/or parts. Part Instances, which are recognized from PDM, are automatically converted to Part Instances on import into HyperMesh.
Only CAE parts and part assemblies can be manually created in HyperMesh. PDM parts and part assemblies must be imported into HyperMesh.
Organize part assemblies, parts, and components in your model.
Translate, rotate, reflect, scale, and position selected parts and part assemblies.
The part assembly can be saved as a self-contained binary file, which will include the part assembly based hierarchy and attributes such as components, properties, and materials.
The CAD representation is typically the original source of information of what a physical part will look like. It forms the basis of the Common representation, which in turn is the basis of all subsequent discipline specific mesh representations. A part can contain multiple representations.
Create your own user defined representation. User defined representations are saved to the settings and will be available in subsequent HyperMesh sessions.
Part representations can be added from external sources such as solver decks and HyperMesh binary files or from the Part Library.
Review library content using the Library Viewer.
Part representations can be loaded from your current HyperMesh session or from the Part Library.
Restore part representations to their original state.
Unload part representations from a session.
Sync PDM metadata (PDM PID, PDM Thickness, PDM Material, and PDM MID) based on a selected part or part's metadata (PID, Thickness, Material, MID).
After importing a BOM and creating respective representations, you can save the representations locally or in the Part Library.
Part representations can be deleted from the current HyperMesh session and from the Part Library.
Settings to configure the representation entity management behavior.
Manage, control and update Major, Study and Library Part revisions using the Part Library.
Group common and unique parts/part assemblies together in part sets, and organize parts and part sets that are unique to a configuration.
Using PDM live connection, on-demand downloading of datasets from external PDM systems such as Teamcenter is possible
All BOM-related information, including part/assembly hierarchy, part attributes, and representation information is organized and displayed in the Part Browser.
Also referred to as Postgres, PostgreSQL is an object-relational database management system with emphasis on extensibility and standards compliance.
Use the automotive section library for rapid concept development in the early phases of the vehicle design process.
Use the Organize tool to move or copy entities into their proper destinations.
Automatically group selected parts into part sets based on comparison method and criteria selected.
Use the Renumber tool to review and organize the IDs of model entities.
Manage all of the IDs for the entities that you create, and define ID ranges for all of the entities in each Include file in relation to the full model in order to avoid ID duplication.
Create and articulate a kinematic mechanism based on FE mesh using the Mechanism Browser.
Local coordinate systems can be used for setting up loads/boundary conditions that do not act in the global axis direction, transforming results, defining material orientation, and many other operations.
Define physical and mathematical characteristics of parts.
Use the Auto Contacts tool to determine contact interfaces between selections of components or elements. Based on the user-specified options like proximity tolerance, surface creation method, main surface type, and secondary type, the tool generates contacts based on set segments or node and element combinations.
Create, review, and edit RBE2/RBE3 elements and MPC equations.
Use the curve editor to create and plot XY curves.
The Abaqus solver offers the flexibility of modeling rigids as surfaces using primitive geometry.
ON THIS PAGE
ON THIS PAGE
