The ribbon allows you to quickly access tools and standard functions, and is located along the top of HyperWorks. Click on an icon to open the related tool. Hovering over a group of icons may reveal additional tools.
Context menus are floating menus that are accessed by right-clicking on elements in the user interface. They provides
immediate access to a short list of commands that are contextually relevant to the selection.
The Message Log lists the actions performed in the current session. The dialog also provides you with information about your file
(warnings, errors, and so on).
Quickly find and open the tools, panels, and browsers that are available from the ribbons or from the Utility
Browser, as well as create entities and solver cards.
Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
The status bar displays information
pertaining to the currently loaded model, active tools and panels, current collectors,
and snap filter
options.
The status bar is located at the bottom of HyperWorks below the modeling window. It contains an area for messages on the left and buttons to the right.
Message Area
The message area displays messages and descriptions of active features in the User
Interface.
When you are on one of the main panel menu pages, a description of the active menu
page name, for example, Geometry, displays.
When you are in a panel, the panel title and subpanel title display.
Errors messages and miscellaneous messages such as status updates, entity selections,
or completed operations also display and temporarily override the title and status
information.
Tip: If you have trouble completing an operation, check
that status bar for relevant information.
Button Area
The button area shows the name and ID of current collectors in the HyperWorks session, as well as snap filter options.
Right-click on any button to customize the status bar button
area. You can show or hide any combination of available items.
To assign or change a current collector, click the respective button on the status bar and select it from the pop-up list or by picking it in
Tip: While choosing a
current collector, you can also create a new one directly from the pop-up list
by using the right-click menu (except for Current Part, which requires using the
Part Browser).
