General data for the run.
The filepath: project directory/Input_Files/Basic/general.dat
- BAS_OR_ADV
- (INTEGER)
- Defined whether the run uses only the basic parameters or the advanced
parameter, too.
- 1≤ BAS_OR_ADV≤2.
- BAS_OR_ADV=1
- Only the basic parameters are used in the run.
- BAS_OR_ADV=2
- The basic parameters and the advanced parameters are used in
the run.
- I_COR
- (INTEGER)
- Index for the number of soil input files.
- 1≤ I_COR ≤ 2.
- I_COR=1
- The terrain is described in the file
soil_input_1.dat.
- I_COR=2
- The soil profile is described in NG files. This option
allows a different description for each track group.
- NMSC
- (INTEGER)
- Numerical method for the sinkage calculation:
- NMSC=1
- Iteration method.
- NMSC=2
- Newton-Raphson Method.
- NMSC=3
- Combination of the two previous methods.
- NMSC=4
- Halving interval method.
- NMSC=5
- Direct calculation method; valid for 2D riding only.
- If NMSC<1 or NMSC>5, the value
of NMSC is set to 2.
- RADDEG
- (INTEGER)
- Radians or degrees.
- If RADDEG=1, the input angle is given in
radians.
- If RADDEG=2, the input angle is given in degrees.
This parameter is effective for any input angle.
- R_CASE
- (INTEGER)
- The input report of the softsoil model. 0≥R_CASE≥2.
The report prints to the model log file.
- For R_CASE=0, the input is not reported.
- For R_CASE=1, the input is partially reported.
- For R_CASE=2, a full report is generated.
