Optimization algorithms work to minimize (or maximize) an objective function subject
to constraints on design variables and responses.
The optimization to be solved is expressed as follows:
Minimize: |
(objective function) |
Subject to: |
(inequality constraints) |
(equality constraints) (design limits)
The functions
are assumed to have the form:
In this formulation:
is an n-dimensional vector of real-valued
design variables
and
are the lower and upper bounds,
respectively, on the design variables
is the set of states that the solver uses to
represent the system
is the value of the function from a previous
simulation. For the first simulation, it is always zero.
The goal of the optimization effort is to minimize the objective function
while satisfying the constraints
. Constraints are assumed to be inherently nonlinear.
They can be either inequality or equality constraints.
and
define the lower and upper bounds for the elements
of
. The set of all allowable values of
is known as the design space for the problem. A
design point or a sample point is a particular set of values within the design
space.
A design point is said to be feasible if and only if it satisfies all the
constraints. Correspondingly, a design point is said to be infeasible if it violates
one or more of the constraints. Our aim, of course, is to find a feasible design.
Sometimes, due to the presence of constraints, this may not be possible.
Many different methods are available for solving the above-mentioned optimization
problem. All of these iterate on the design
in some manner to find a better solution. A generic
algorithm that describes this process is:
- An initial value for the design variables
is provided to the optimizer.
- The response quantities
are computed by running a simulation.
- Some algorithm, sometimes a sensitivity-based method, is applied to generate
a new
that will either reduce the objective
function, reduce the amount of infeasibility, or both.
- When a sensitivity-based method is used, the optimizer also needs to compute
the sensitivity of the functions
with respect to the design
. This means the optimizer requires the
matrix of partial derivatives,
- In an iterative fashion, new designs (
) are generated by the optimizer until a
determination is made that the optimizer has found a minimum or the
iteration limits have been exceeded.
In some instances you may want to maximize the value of a certain objective. Without
any loss of generality, you can convert it to a minimization problem by simply
negating the objective you calculate. Thus, if you want to maximize a function
defining the cost function as
