Run MotionSolve from MotionView
The Run Solver panel in MotionView allows you to run MotionSolve directly from MotionView.
You can either run the current model or run an existing MotionSolve command file generated previously by MotionView.
Figure 1. Run Solver Panel with the MotionSolve Solver Selected
Figure 2. Run Solver Panel with the MotionSolve File Option Selected
