Solution Sequences
OptiStruct can be use different solution sequences for aircraft analysis.
- Type
 - Description
 - STATICS
 - Linear Static or Nonlinear Static Gap Analysis
 - MODES
 - Normal Modes Analysis
 - BUCK
 - Linear Buckling Analysis
 - DFREQ
 - Direct Frequency Response Analysis
 - LGDISP
 - Large Displacement Nonlinear Static Analysis (available as PARM card entry)
 - HEAT
 - Linear Steady-state or Transient Heat Transfer Analysis
 - FATIGUE
 - Fatigue Analysis
Static Analysis
Figure 1. Stress and Displacement Contours for Static Analysis of a Fuselage Section
For further information, refer to Linear Static Analysis.
- Material nonlinearities
 - Geometric nonlinearities
 - Presence of nonlinear forces
 - Contact nonlinearities
Inertial Relief Analysis
- PARAM, INREL, -1 is used when certain boundary conditions are specified.
 - PARAM, INREL, -2 is used when no boundary conditions are specified.
Figure 2. Displacement and Stress Contours for Inertia Relief Analysis
Figure 2 shows the results from an Inertia Relief Analysis performed on a fuselage model.
- Under constrained and loose components
 - The rotating speed which matches the natural frequencies in case of the analysis of a blade or a rotor
 - The areas to be constrained or loaded.
Figure 3. Normal Modes Analysis of a Fuselage and Drone
Figure 3 shows the results from the Normal Modes Analysis for a fuselage and a drone. Both models have free-free boundary conditions.
Figure 4. Frequency Response Analysis of a Fuselage Section
Model File
The model file used here includes:
Fixedwing_modal.fem
