OS-T: 1050 Connection of Dissimilar Meshes using CWELD Elements
In this tutorial, an existing finite element model of a simple cantilever beam is used to demonstrate how to connect dissimilar meshes using CWELD elements.
![rd1050_cant_beam](../../../images/solvers/rd1050_cant_beam.png)
Figure 1. Cantilever Beam with Dissimilar Meshes
Launch HyperMesh and Set the OptiStruct User Profile
Open the Model
Set Up the Model
Create CWELD Elements
Submit the Job
- dissimilar.html
- HTML report of the analysis, providing a summary of the problem formulation and the analysis results.
- dissimilar.out
- OptiStruct output file containing specific information on the file setup, the setup of your optimization problem, estimates for the amount of RAM and disk space required for the run, information for each of the optimization iterations, and compute time information. Review this file for warnings and errors.
- dissimilar.h3d
- HyperView binary results file.
- dissimilar.res
- HyperMesh binary results file.
- dissimilar.stat
- Summary, providing CPU information for each step during analysis process.
