OS-T: 3400 Design an Open Hole Tension (OHT)
Composite materials have become popular in the application of a variety of structures. The need for innovative designs has posed a great challenge. In this tutorial you will perform an optimization-driven design approach of an open-hole tension specimen using OptiStruct.
Before you begin, copy the file(s) used in this tutorial to your working directory.
The design takes a three-phased approach:
Phase 1: Reference Design Synthesis (Free-size Optimization)
Concept design synthesis Free-size optimization identifies the optimal ply shapes and locations of patches per ply orientation.
Phase 2: Design Fine Tuning (Size Optimization)
Design fine tuning Size optimization identifies the optimal thicknesses of each ply bundle.
Phase 3: Ply Stacking Sequence Optimization
Ply stacking sequence optimization Shuffling optimization obtains an optimal stacking sequence.
The process expands upon three important and advanced optimization techniques; free-size optimization, size optimization and ply stacking sequence optimization. By stringing these three techniques together, OptiStruct offers a unique and comprehensive process for the design and optimization of composite laminates. The process is automated and integrated in Altair Simulation by generating the input data for a subsequent phase automatically from the previous design phase.
Together with these steps, an initial and final analysis will be utilized to determine the baseline and final characteristics of the designed part.
Model Definition
The composite design optimization methodology presented within this tutorial was developed to solve very complex composite design optimization problems. The methodology breaks down the complex composite design optimization problem, which is not solvable by itself, into several simpler composite design optimization problems, which are solvable by themselves. The cumulative solution to each of the simpler composite design optimization problems provides a solution to the complex design optimization problem. This process of breaking down complex problems into several simpler problems is consistent with the engineering method.
os3400_ph0_introduction_image
Figure 1. Model Overview
