OS-V: 0360 Simply-Supported Thin Square Plate Harmonic Random Vibration Response
Test 13R OptiStruct is used to investigate the Peak Displacement in z-direction and extreme fiber bending stress at undamped Natural Frequency (at the center of the plate).
![](../../../images/solvers/nafems_simply_supported_thick_square_plate_harmonic.png)
Figure 1. FE Model with Boundary Conditions and Loadcases
Benchmark Model
The 2nd order and 1st order quad elements are used to model the square plate of thickness 0.05m. The z-rotation and x, y translations are fixed for all the nodes, z-translation is fixed along all four edges, x-rotation is fixed along the edge x=0 and x=10 and y-rotation is fixed along the edge y=0 and y=10. A steady-state random forcing with uniform power spectral density (of force) PSD= (100 N/m2)2/Hz is induced in the z-direction. For modal analysis solution, a damping ratio of 0.02 is applied in all 16 modes and for direct solution, Rayleigh damping factor α1=0.299 and α2=1.339×10-3 are given.
- Material Properties
- Value
- Young’s Modulus
- 200 × 109 N/m2
- Poisson’s Ratio
- 0.3
- Density
- 8000 kg/m3
Frequency Response Summary
f*
- Closed form solution
Peak Displacement PSD (mm2/Hz) | Peak Stress PSD ((N/mm2)2/Hz) | Frequency (Hz) | |
Reference Solution | 2063.20 | 1025.44 | 2.377 |
HOE | |||
Direct Solutions | 2232.98 | 1411.14 | 2.322 |
Normalized | 0.923967075 | 0.726674887 | 1.023686477 |
Modal Solution | 2241.33 | 1416.89 | 2.324 |
Normalized | 0.920524867 | 0.723725907 | 1.022805508 |
LOE | |||
Direct Solutions | 2045.23 | 951.00 | 2.349 |
Normalized | 1.008786298 | 1.078275499 | 1.011919966 |
Modal Solution | 2065.73 | 960.22 | 2.345 |
Normalized | 0.998775251 | 1.067921935 | 1.013646055 |
Model Files
- Test13RHOED.fem
- Test13RHOEM.fem
- Test13RLOED.fem
- Test13RLOEM.fem
Reference
NAFEMS R0016 - Selected Benchmarks for Forced Vibration, J Maguire, D J, Dawswell, L Gould 1989
