OS-V: 0365 Simply-Supported Thin Square Plate Transient Forced Vibration Response
Test 13T OptiStruct is used to investigate the Peak Displacement in z-direction, the time at the peak displacement, extreme fiber bending stress at undamped Natural Frequency and the Static displacement at the center of the plate.
![](../../../images/solvers/nafems_simply_supported_thin_square_plate_transient.png)
Figure 1. FE Model with Boundary Conditions and Loadcases
Benchmark Model
The 2nd order and 1st order quad elements are used to model the square plate of thickness 0.05m. The z-rotation and x, y translations are fixed for all the nodes, z-translation is fixed along all four edges, x-rotation is fixed along the edge x=0 and x=10 and y-rotation is fixed along the edge y=0 and y=10. A suddenly applied step load F0=100 N/m2 is induced in the z-direction. For modal analysis solution, a damping ratio of 0.02 is applied in all 16 modes at a time step of 0.002 secs and for direct solution, Rayleigh damping factor α1=0.299 and α2=1.339×10-3 at a time step of 0.002 secs are given.
- Material Properties
- Value
- Young’s Modulus
- 200 × 109 N/m2
- Poisson’s Ratio
- 0.3
- Density
- 8000 kg/m3
Frequency Response Summary
f*
- Closed form solution
Peak Displacement (mm) | Time at Peak Displacement (sec) | Peak Stress (N/mm2) | Static Displacement (mm) | |
Reference Solution | 3.523 | 0.210 | 2.484 | 1.817 |
HOE: | ||||
Direct Solution | 3.637 | 0.212 | 2.784 | 1.832 |
Normalized | 0.968655485 | 0.990566038 | 0.892241379 | 0.991812227 |
Modal Solution | 3.643 | 0.210 | 2.820 | 1.832 |
Normalized | 0.967060115 | 1 | 0.880851064 | 0.991812227 |
LOE: | ||||
Direct Solution | 3.465 | 0.210 | 2.244 | 1.780 |
Normalized | 1.016738817 | 1 | 1.106951872 | 1.020786517 |
Modal Solution | 3.454 | 0.214 | 2.203 | 1.779 |
Normalized | 1.019976838 | 0.981308411 | 1.127553336 | 1.021360315 |
Model Files
- Test13THOED.fem
- Test13THOEM.fem
- Test13TLOED.fem
- Test13TLOEM.fem
Reference
NAFEMS R0016 - Selected Benchmarks for Forced Vibration, J Maguire, D J, Dawswell, L Gould 1989
