OS-V: 0370 Simply-Supported Thick Square Plate Harmonic Forced Vibration Response
Test 21H OptiStruct is used to investigate the Peak Displacement in z-direction and extreme fiber bending stress at undamped Natural Frequency (at the center of the plate).
![](../../../images/solvers/nafems_simply_supported_thick_square_plate_harmonic.png)
Figure 1. FE Model with Boundary Conditions and Loadcases
Benchmark Model
The 2nd order and 1st order quad elements are used to model the square plate of thickness 1.0m. The z-rotation and x, y translations are fixed for all the nodes, z-translation is fixed along all four edges, x-rotation is fixed along the edge x=0 and x=10 and y-rotation is fixed along the edge y=0 and y=10. A steady-state harmonic forced vibration F=F0 sin ωt is induced in the z-direction. (F0=106 N/m2 over whole plate, ω=2πf, f=0 to 78.17 Hz). For modal analysis solution, a damping ratio of 0.02 is applied in all 16 modes and for direct solution, Rayleigh damping factor α1=5.772 and α2=6.926×10-5 are given.
- Material Properties
- Value
- Young’s Modulus
- 200 × 109 N/m2
- Poisson’s Ratio
- 0.3
- Density
- 8000 kg/m3
Frequency Response Summary
f*
- Closed form solution
Peak Displacement (mm) | Peak Stress (N/mm2) | Frequency (Hz) | |
Reference Solution | 58.33 | 800.8 | 45.90 |
HOE: | |||
Direct Solution | 62.633 | 943.67 | 45.21 |
Normalized | 0.931298197 | 0.848601736 | 1.01526211 |
Modal Solution | 62.67 | 944.57 | 45.23 |
Normalized | 0.930748364 | 0.847793176 | 1.014813177 |
LOE: | |||
Direct Solution | 60 | 774.73 | 45.62 |
Normalized | 0.972166667 | 1.033650433 | 1.006137659 |
Modal Solution | 60.05 | 774.54 | 45.59 |
Normalized | 0.971357202 | 1.033903995 | 1.006799737 |
Model Files
- Test21HHOED.fem
- Test21HHOEM.fem
- Test21HLOED.fem
- Test21HLOEM.fem
Reference
NAFEMS R0016 - Selected Benchmarks for Forced Vibration, J Maguire, D J, Dawswell, L Gould 1989
