When there is no sensor to activate the gas injection, the vent holes and porosity
become active when
, or if the pressure
value longer than the time given in
, where all these values are input using
/MONVOL/FVMBAG1.
When at least one of the injectors is activated by the sensor, then activation of
venting and porosity options is controlled by
Ittf.
Tinj is the time of the first
injector to be activated by the sensor.
Ittf =
0
Venting,
Porosity |
Activation |
When
, or
Deactivation |
Tstop |
Time dependent
functions |
No shift |
Ittf =
3
Venting,
Porosity |
Activation |
When
and
, or
Deactivation |
Time dependent
functions |
Shifted by
All other related curves are active when corresponding venting, porosity or
communication option is active.
