Drill Size of Via
Check the drill size of vias.
- Target Object Definition: Set target vias that users want to find out on
design.
Figure 1.- Through Via Drill Hole: Set the through via’s drill hole size with minimum value.
- Blind Via Drill Hole: Set the blind via’s drill hole size with minimum value.
- Buried Via Drill Hole: Set the buried via’s drill hole size with minimum value.
- Exclude Checking for Via Hole Size in Ranges: Among via holes defined in the
table above, exclude checking for vias that have hole sizes in the ranges of
the table below's setting.
Figure 2.- Item: Specify the item name.
- Min Diameter: Set the via hole’s minimum hole diameter to be excluded in checking.
- Max Diameter: Set the via hole’s maximum hole diameter to be excluded in checking.
- Min Length: Set the via hole’s minimum hole length to be excluded in checking.
- Max Length: Set the via hole’s maximum hole length to be excluded in checking.
