Mechanical Short
Check an electrical short of different routing patterns.
In case of objects, Via, pattern or NC pins which are not belonging to net, have connection with two different routing patterns.
Target Object Definition: Define target objects.
  1. Non-Electrical Via: Vias which are not belonging to any nets will be target objects.
  2. Net Name un-assigned Pattern and Polygon: Pattern or polygon which is not electrical net assigned will be target object.
  3. NC Pin: NC pins will be target objects
