File Operations
Perform file operations like edit and save, download, tail and delete the files.
| Icon | Description |
View file details such as the last modified timestamp, owner, and file size. |
Download the file to your local machine. |
Opens the file in edit mode so that you can modify the contents of the file. In the Edit mode view, you will have Save and Cancel options. |
To refresh the file contents and to view the last lines of a file. In the Tail mode view, you will have Play, Pause, and Stop options. |
Provides an option for deleting the file from the remote server. |
