Zip Files and Folders
Archive files and folders by zipping them.
- Click the Files tab located in the upper left-hand of the page.
- Using the file system tree on the left, navigate to the location where you want to zip the files or folders.
Right-click on the folder or files.
Tip: You can select multiple files or folders. Select the first file by clicking its name and hold down CTRL and select each file by clicking its name.
Select Compress.
Figure 1. Compress a FileThe files and folders selected will be zipped and placed in the same path.
Figure 2. Zipped File
